Home > Technical (L322) > Whole centre console not working! Smell of burning ... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
please update your car profile so we know what you have... ... - .- -.
17th Oct 2014 10:25pm |
andrew-a Member Since: 07 Sep 2011 Location: Wirral Posts: 70 |
2003 4.4 petrol |
17th Oct 2014 10:30pm |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 |
Andrew, what Stan means is to edit your profile in settings so the footer of your posts shows what you have for a Fatty.
18th Oct 2014 12:33am |
I have updated it, but it doesn't show -nothing seems to be working at present and it's just not the car! |
18th Oct 2014 7:58am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
It's pretty easy to have a look behind the panel. There is a single screw on the side panel in the footwell, and then the wooden bits at the side of the switches clip off sideways.
18th Oct 2014 8:58am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
100% get the AA/RAC to recover it to a professional before you turn into a statistic my friend...I personally would not drive it one more inch before resolving the problem... |
18th Oct 2014 9:04am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
What could possibly go wrong Craig?
18th Oct 2014 10:13am |
Thanks guys. I have removed the ventilation facia and the main wire loom connector (it's blue on my car) has burnt out, but seems to have welded onto the panel. Everything else works, even the rear blower. So what's the damage and how much? It will need some loom, the blue connector and maybe the motherboard on to which it attaches as that may have been burnt as we'll |
18th Oct 2014 10:19am |
You can't just replace them without finding the source of the overload sir... Else you will just burn out the next plug & potentially more next time around...
18th Oct 2014 10:29am |
Yes I agree. Just need to fully disconnect it now to ensure that it doesn't cause further problems but I can't get the main loom off as it's welded to panel. Which connection transfers the power to the unit - does anyone have a photo or diagram? Thanks |
18th Oct 2014 11:20am |
