Home > In Car Electronics (L322) > Bluetooth connects but no vol |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
press the left tone button on the nav unit for about 3/4 seconds and it will bring up a 'volume' screen where you can adjust the relevant defults there..
8th Oct 2014 2:58pm |
tymtym Member Since: 07 Oct 2014 Location: wales Posts: 4 |
Hi thanks for reply Stan tried that m8 so turned it nearly all way up still nothing |
8th Oct 2014 3:28pm |
Jez/revere Member Since: 23 Sep 2015 Location: Scunthorpe Posts: 2 |
Hi there,I'm new to this too....
23rd Sep 2015 10:52am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Is the other person able to hear you when you make a call ??
23rd Sep 2015 11:01am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
It might be worth re-flashing the bluetooth module. You would need to have a dealer to do that unless you purchase the GAP iiD tool which is an invaluable piece of kit to have for all sorts of functions. The BT version, although more expensive, is the most versatile. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
23rd Sep 2015 11:21am |
cropps Member Since: 07 Aug 2014 Location: Lancashire Posts: 32 |
Hi
23rd Sep 2015 11:34am |
Yeah that's right,connects but nothing can be heard both ends!
23rd Sep 2015 12:09pm |
unit is left side at the very top - NOKIA stamped on it. Regards
23rd Sep 2015 12:42pm |
Mine was an after market unit fitted behind centre console & tapping into speaker system wiring at that point. |
23rd Sep 2015 9:28pm |
another question : when you dial a number can you hear the ring tone through the stereo ??
25th Sep 2015 2:31pm |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
I'm having the same problem on mine (05 Vogue with the Jag head unit) - phone connects fine, dials on the screen but there is no dialling tone or voices through the stereo even with the volume properly adjusted. If I pick up the phone from the cubbyhole (whilst stationary I hasten to add) and change the sound output from "bluetooth speaker" to "handset", I can talk through it normally - so the problem obviously lies with the car not the connection.
19th Oct 2015 8:34am |
You will need to remove the unit to check it properly.
19th Oct 2015 9:31am |
Only real way to be sure is to swap it with another unit.
19th Oct 2015 10:03am |
What is the upgraded phone unit? And is it plug and play with the rest of the 05 system? NW060
19th Oct 2015 10:27am |
