Home > Maintenance & Mods (L322) > mettalic creaking grating on turning right from rear
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Hi. As it was a nice day I drove with all windows open.
On turning right I could here a metallic rusty noise from I guess the back of car right side.
I fear a diff problem but noise may not actually be that heavy. More like two rusty springs being rubbed together side by side.
Only happens turning to right. Left turn ok but I cannot keep driving routes using left turns only as the fuel costs are too high.
Closing the window help eliminate noise Very Happy
Appreciate any advice thanks.
Post #284554 5th Oct 2014 9:47pm
Googsy
Does it sound like an old rusty pram? I had this and turned out to be bushes on front of car. Mine too was when I turned right. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #284566 5th Oct 2014 11:14pm
Sticky brake pad? Got - 2017 SDV8 Autobiography in Loire Blue
Post #284567 5th Oct 2014 11:15pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
One of The front brake back plates may have come loose I had the same thing and was convinced the noise was coming from the rear turned out the back plate on the front drivers side had come away after the bolt holes had rusted , I cut both sides off and it's been like that for over a year now with no problems
Post #284572 6th Oct 2014 6:11am
SMUTT
Thank you for the terrific response to this - I would say it is possibly like a rusty pram, a rotational / speed related noise
Thinking about it its almost like someone rubbing a rusty spring against rusty bike spokes as the bike wheel rotates.
I shall try and get some better look at front and rear brakes and bushes when I get a break from full time wife / daughter / work.
Post #284649 6th Oct 2014 4:13pm
Would check all your disc back plates for play, one may have come adrift. There is nothing that can't be fixed with a hammer😜😜
Post #284673 6th Oct 2014 6:24pm
