Home > In Car Electronics (L322) > Heated door mirrors ?
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Hello trying to get to the bottom of my door mirrors. They don't seem to hear up when I use the rear heated window. Does anyone have a wiring diagram to check to see if there is any power getting there for starters ? Thumbs Up
Steve
Post #284106 2nd Oct 2014 6:00pm
espaceboy
Perhaps just remove the glass, be brave with a wide leaver
then measure Voltage
rave has the diagrams, sure its the two black wires in the loom going to c2271 pins 6 &7 back of door switch module
Post #284109 2nd Oct 2014 6:36pm
Steverr
Does the glass just pop out ?
Post #284117 2nd Oct 2014 7:07pm
espaceboy
Yes it does, again rave gives you some tips
Position 2 levers to lower edge of mirror glass surround, apply vertical leverage.
Continue to apply an even but constant pressure, until glass releases from mounting.
Post #284118 2nd Oct 2014 7:10pm
mike37
I thought they only came on with the front demist program?
Post #284209 3rd Oct 2014 6:41am
mjdronfield
I thought they only came on below a certain temp.
I'll have to read up later....you could be right.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #284210 3rd Oct 2014 6:58am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Just checked my handbook - says they come on automatically when a certain temp is reached (no idea what temp though) !!
cheers
RP
Post #284215 3rd Oct 2014 8:52am
Steverr
Ok guys thanks for the replies. I managed to pop the glass off.. Pretty easy really... Tested for a current and have defiantly got power going in. But 2 bits of wire and a bulb on these 2 wires. Thing is its not a constant power, it flashes.... say every 2 seconds..... Thought it would be on constantly.
Post #284290 3rd Oct 2014 6:42pm
Steverr
Ok just found a fault on the IDD tool saying...AO driver door mirror heater: open circuit
Can anyone explain what this means to me please
Steve Thumbs Up
Post #285487 10th Oct 2014 4:07pm
open circuit means a break in the supply of power , maybe the wires are chaffed or broken? ... - .- -.
Post #285492 10th Oct 2014 4:14pm
Steverr
Ok Stan thanks, will investigate further!!!
Post #285514 10th Oct 2014 5:15pm
Take the glass out and test by supplying 12v if they warm then the glass is fine and the real fun begins. The two cables run in through the door behind the door card to their own connector IIRC. From there they go into the door loom and then into a whole army of cables Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #286255 13th Oct 2014 2:35pm
Steverr
Thumbs Up thanks for that ... Can't wait Thud
Post #286321 13th Oct 2014 7:31pm
Steverr
Ok checked the glass on the mirrors.. One heated Thumbs Up up the other didn't !!! Big Cry
Could check the supply as it was 18 degrees so wouldn't of kicked in anyway....
Post #287544 19th Oct 2014 4:16pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
So, if we are above a certain temperature, they will not work?
I keep getting fault come up on passenger door heated mirror, saying its a short or ground problem.
Can some one tell me which fuse it is please?
Post #685198 9th Feb 2024 4:32pm
