Home > General > Service Plan
Brokenfather
Service Plan
Hello good people.
I purchased my Range Rover TDV8 in March 2010 and it came with the remains of a 3 year service plan I believe.
It was new on 31st Jan 2008. It was serviced (Oil) in Jan 2009 at 6000 odd miles, and again (service 1) in Dec 2009 at 8000 odd miles. The mileage now is 17000.
I appreciate that the car states when a service is required, but looking on the net this appears to be every 15000 miles.
I wont get to 23000 miles by either Dec 2010 or Jan 2011.
Does anyone know if I can perhaps insist on an annual service under the plan even if the car isn't saying it is needed please?
Ta.
Post #28393 18th Sep 2010 2:29pm
I had mine serviced every year , as my first year i had only done 7000 miles , second year 18000 miles , and third year 26000 , The dealership told me it was up to myself if i wanted it done either 12 monthly or by mileage ..... Thumbs Up
Post #28397 18th Sep 2010 2:59pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Re: Service Plan
Brokenfather wrote:
...I purchased my Range Rover TDV8 in March 2010 and it came with the remains of a 3 year service plan I believe...
Being the new owner - have you made sure this service plan has been transferred to you?
Not sure if you have to, but it might have some sodding clause that prevents you from being entitled to use it.
Post #28400 18th Sep 2010 3:09pm
Mine just did over 18,000 without even starting the service count down. I blinked and booked it in anyway ,the dealers weren't in the least bit concerned. 2008 MY Supercharged
Post #28404 18th Sep 2010 3:56pm
Brokenfather
Thanks guys, but you are missing the point I'm afraid.
If possible I want to get it serviced before the end of Jan 2011 as to me it will be free because it should be covered by the 3 year prepaid Service Plan.
I am trying to ascertain if the dealer will do so under the Service Plan if the car doesnt say it is needed.
Post #28406 18th Sep 2010 4:07pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I understood the service interval was 15k OR annual - whichever comes first. In other words, if you only do 5000 miles in a year then the car is still due a service at the end of the 12 months. If not, it could be 3 years between services. Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #28407 18th Sep 2010 4:35pm
Vogue
JMC, that is my understanding of it as well.
Post #28423 18th Sep 2010 8:05pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
The Tdv8's warn you about services. this can be at 1000 miles or 25000 miles. The main parameter is fuel comsumption, on the car's internal computers. Meaning, if you drive always at 120mph, expect service at 1000 miles. If you drive like an old lady, expect a lot more.
My dealer had a customer who made 30000kms without warnings.
Mind, the car will also warn about the yearly service. My car is booked for next week, and right now is asking for an oil service and a yearly service.
Post #28426 18th Sep 2010 8:25pm
Brokenfather
Thanks all.
Assuming the default of 12 months applies I should be okay for a free service in December 2010.
Post #28432 19th Sep 2010 7:56am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Despite all the service indicators and instructions in manuals etc you can have your car serviced whenever you like BUT if you don't have at least an annual service or a service within 3 months of the service indicator coming on then if the car is still within warranty then you will loose the LR 3 year warranty as the car will not have been serviced WITHIN the makers recommendations(I had this hapen to me last year when a trip abroad meant being away over the 3 months period when the service would be due - the dealer serviced the car 2 months before the count down would have started).
My understanding is that regardless of the service indicator an annual service is required ie every 12 months at least an oil/filter change service is required. Our American friends often have a problem grasping that modern synthetic oils can go as long as 18-20000 miles and over on RRSport and RRNet, we often used to be asked why the car was expected to go so long on "old" oil when they had been used to a) extremely cheap oil, b) low tech engines c) car makers who worked in cahoots with the oil companies and "recommended" 3000 mile oil change intervals - many still find it difficult to break the oil changing habit even though it is unnecessary, even though it does no harm to change the oil more frequently. if the maker says that the car can go longer between changes whgy do it more often, especially in Europe where oils are so expensive. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #28434 19th Sep 2010 8:33am
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
when we bought our bmw second hand, the extended warranty was none transferrable to us, it was only for the original owner and once sold was void , maybe you should ask lr if its the same berore you book it in 2002 td6 vogue, 06 supercharged facelift
Post #28443 19th Sep 2010 11:16am
