Home > Technical (L322) > cornering lights
cornering lights
a question for those of you that have cornering lights, do you find them distracting?
every time i turn a corner [slow] these things come on and i automatically look at what they are illuminating thus taking my eyes of the road in front..any one have the same problem. ... - .- -.
Post #283179 27th Sep 2014 8:10pm
miggit
I don't have those Sad
Did have them on an ausy spec Nissian Patrol, they were the best thing since sliced bread, saved me from may a misshap in the dark, like gate posts and tree stumps. But they were only 21w normal indicator light bulbs, maybe you could try a lesser wattage, and reduce the risk of melting the light fitting too!
Post #283188 27th Sep 2014 8:23pm
i have 35 watt halogens and they are pretty bright so you can imagine the distraction..my thoughts are to disconnect them as i live in lit streets and they are of no use really. ... - .- -.
Post #283200 27th Sep 2014 8:36pm
Sandyt
Have to say Stan I don't have that problem and also I don't know what size the bulbs are but they are bright but I just ignore them
Post #283207 27th Sep 2014 8:40pm
thanks sandy Thumbs Up ... - .- -.
Post #283210 27th Sep 2014 8:42pm
miggit
Word of caution, if you disconnect them......... will you not suffer the constant BONG? If you cant get them in a low wattage, can you find the equivalent 24v bulb, that'll dim things down!
Post #283230 27th Sep 2014 9:36pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Should your eyes not be looking in that direction anyway when cornering? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #283254 28th Sep 2014 6:23am
pld118
Stan,
Quite some time ago I fitted the below LED cornering bulbs in place of the he OE bulbs.
They compliment the colour of the main factory Xenons and also my 'upgraded' 5630 LED sidelight bulbs very well.
They do still provide some cornering light although nowhere near as intense or distracting as the OE sidelight bulbs. Purists might say they are ineffective compared to the OE bulbs and that they are for aesthetic effect only as they do look good Mr. Green
One other benefit I've found with these LED bulbs is that they seem less likely to melt the cornering bulb housing (a known issue on these cars if the steering is left on turn/ lock for a longer period of time) as the 'upgrade' LED bulbs don't seem to generate as much heat.
** Cornering LED bulbs from hq_auto_lighting_uk on eBay. Paid £25/ pair incl del –
H8 PGJ19-1 Xenon WHITE 29W HIGH POWER CREE LED
http://www.ebay.co.uk/itm/310670163821?ssP...5091237216
Post #283258 28th Sep 2014 7:45am
ebajema
I don't find the distracting at all and quite helpful in darker areas. In light areas I don't really notice them much Smile.
Maybe I'm not easily distracted Smile Smile Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #283266 28th Sep 2014 8:19am
@miggit, disconnecting them wont be a problem as i can switch off the hot/cold monitoring with the iidtool.
@appj62, i should keep my eyes on where i'm going but as said in the first post ,its distracting.
@ryan, i've thought about leds but i fear me looking to see if they are still working.
@eugene, where you live they would be a plus but the streets a journey through are very well lit.
so if i did disconnect them or take them out, any suggestions of what could i replace them wiith, maybe drl's? blues? Mr. Green ... - .- -.
Post #283269 28th Sep 2014 8:40am
miggit
Stan mate I've got it, leave the lights in place and fit the driver with some blinkers Rolling with laughter
Post #283297 28th Sep 2014 10:55am
Shocked Cool Laughing ... - .- -.
Post #283299 28th Sep 2014 11:00am
supershuttle
They are a bit weird and distracting, my new car has them but hopefully I will get used to them Very Happy Geoff
Post #283341 28th Sep 2014 2:47pm
nah you wont geoff Mr. Green ... - .- -.
Post #283342 28th Sep 2014 2:56pm
miggit
I know a man who has a team of horses and a carriage, if you want me to look in to those blinkers Very Happy
Post #283343 28th Sep 2014 3:01pm
