Home > In Car Electronics (L322) > Blank Screen |
You could PM Baris on here who seems to spend a lot of time with the units in pieces. He will be best to help you fault find from here.
5th Sep 2014 4:03pm |
Or a dodgy connection between the TV and nav ?
5th Sep 2014 4:06pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
You've probably got a dodgy connection in the blue plug, possibly due to past water "issues".
5th Sep 2014 4:09pm |
Kiwi_V8 Member Since: 16 Aug 2014 Location: Auckland Posts: 37 |
Thanks for the tips guys, I think its most likely the connector on the satnav, as it was fine up until the point it was disconnected. Would be a massive coincidence if the tv failed at the same time..
5th Sep 2014 4:19pm |
Thought I would finish this up in case anyone else is having the same issue.
26th Sep 2014 4:10pm |
