![]() | Home > In Car Electronics (L322) > Blank Screen |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
You could PM Baris on here who seems to spend a lot of time with the units in pieces. He will be best to help you fault find from here.
Or a dodgy connection between the TV and nav ?
You've probably got a dodgy connection in the blue plug, possibly due to past water "issues".
Kiwi_V8 Member Since: 16 Aug 2014 Location: Auckland Posts: 37 ![]() ![]() ![]() |
Thanks for the tips guys, I think its most likely the connector on the satnav, as it was fine up until the point it was disconnected. Would be a massive coincidence if the tv failed at the same time..
Thought I would finish this up in case anyone else is having the same issue.
