Home > Maintenance & Mods (L322) > Knocking. Front Drop Link Replace & Freeing Seized Nuts
Page 2 of 4 <1234>
pld118
Cheers Joe! Mr. Green
I opted for the Halfords Breaker Bar as I'd seen a previous post of yours where you reported buying a similar one and seemed quite pleased with the purchase.
When the time came to loosen the lower, M12 size, nut on the passenger side drop link, I also found an Ace in my existing tool pack in the form of a cracking (pun intended!) tool as an alternative to a socket or spanner to fit the nut?.. the wheel brace from within the tool kit that came with my Mercedes Sprinter Bottle Jack! A perfect fit over the nut and after an hour of leaving that nut soaking up some penetrating fluid and followed by a good dose of 'Plus Gas', this wheel brace responded well to my full body weight pulling the lower passenger side nut which loosened very quickly and without need for heat or any cutting tools.
And as many have said, I replaced both front drop links without removing the wheels and with the car locked in off road height.
** Any idea why only the top mount of both front drop links has a washer on the 'blind side' of the nut and not on the bottom one? **
Thanks.
Post #282720 25th Sep 2014 3:40am
Propane blow torch won't produce enough heat to remove stubborn seized nuts or bolts, you need a Mapp Gas blow torch
Quote:
You were only supposed to blow the bloody doors off Laughing Laughing Laughing
Post #282741 25th Sep 2014 9:43am
pld118
Knocking cured !
I'll take your word on that 47P2 but the nut certainly appeared easier to hacksaw after a few minutes of having my wee blow torch breathing fire on it! Laughing
Having test drove the car briefly after replacing the driver's side drop link yesterday, I instantly felt it had solved the knocking noise and so I then replaced passenger side drop link last night to even things up.
Having this morning driven - as normal - all the normal lower speed routes which was when I used to hear the knocking noises, it is obvious that the knocking noise has gone and in fact the car does feel more composed in that it seems to wallow, sway, roll (however you want to describe it) less.
Success Thumbs Up
Post #282748 25th Sep 2014 10:26am
Sandyt
Well done and it was all worth it Thumbs Up Thumbs Up
Post #282872 25th Sep 2014 9:27pm
+1 for mapp gas, super hot! There is nothing that can't be fixed with a hammer😜😜
Post #282873 25th Sep 2014 9:29pm
Bow down Bow down Bow down Congratulations sir Bow down Bow down Bow down
Post #282884 25th Sep 2014 10:28pm
pld118
Thanks Laughing
Post #282903 26th Sep 2014 5:01am
ebajema
Well done. I hate using heat on metal if it can be avoided since you don't know if the material was heat treated and by adding heat to it (and letting it cool quickly) it screws up the material properties (for example making it brittle, a common problem when you cool steel too quickly).
So using mechanical tools, like hacksaws and nut splitters would be my first venture into destructive deconstruction efforts before going for the final final very last resort and that is heat. MY 2010 5.0 SC Galway green and sand interior!!
Post #282904 26th Sep 2014 5:50am
i like those words eugene, ''destructive deconstruction ''
nice job ryan Thumbs Up ... - .- -.
Post #282906 26th Sep 2014 7:05am
pld118
Why only one washer?
Hi,
Joe90 previously confirmed that there is in fact only one washer but...
Does anyone actually know why only the top mount of both front drop links has a washer on the 'blind side' of the nut and not on the bottom one?
Thanks.
Post #286570 15th Oct 2014 1:52pm
Puzzled me for years!!! Rolling Eyes
Post #286668 15th Oct 2014 7:20pm
Someone at Land Rover decided to have a laugh and get everyone wondering why..... Just to Censored Craig off....
Also it's a hardened steel washer so work that one out!!!!! Pete
Post #286677 15th Oct 2014 7:52pm
pld118
Well whether you're both being seious or flippant to my daft question Embarassed
I fitted a washer to the bottom part of my new drop links! Mr. Green
Post #286701 15th Oct 2014 9:49pm
miggit
Just wanted to say that a set of impact sockets (6 slided) are a big help in situations like this, and while I realise that the horse has slung its hook, they might be a consideration before the next job. Also a drill can come in handy, you can drill some holes in the side of the nut, and bash the stuffing out of it with a cold chisel and a knock-o-meter. By drilling the holes before you bash, you remove a lot of the nut and it gives up a lot easier Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #286718 15th Oct 2014 11:11pm
No, being totally serious, it has one, hardened steel washer behind the top fitting, on the "wrong" side, and nothing on the bottom.... but who knows why?? Pete
Post #286729 15th Oct 2014 11:54pm
Page 2 of 4 <1234>
