Home > Technical (L322) > Low Range Over-ride? |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 311 |
I committed the cardinal sin of resurrecting an old thread today! hew ho!
24th Sep 2014 5:00pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 964 |
You could certainly select high range by removing the shift motor and turning the lead screw manually, but you’re up against the transfer box ECU which memorises the shift motor position before the ignition is switched off and will then automatically try to push the selector fork against the range stop it last remembered, to calibrate itself, as soon as you turn on the ignition again.
24th Sep 2014 5:19pm |
Yup. Tried that.
24th Sep 2014 5:23pm |
"Would manually moving the spline drive to high range damage anything?"
24th Sep 2014 6:01pm |
Thanks Phil,
24th Sep 2014 6:04pm |
Yes, from memory that sounds right. Turning the spline clockwise moves the selector fork towards the rear of the vehicle i.e. pulls it towards you, which selects high range. The force on the lead screw acts into the casing so it doesn't try to eject itself.
24th Sep 2014 6:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
I used a spare shift motor with motor casing removed, fitted to TB and then span the windings until back up into high range, then refitted original motor (with missing spline in correct position for high range on the motor)
24th Sep 2014 9:25pm |
Thanks Joe. I'm full of confidence now to tackle this
24th Sep 2014 9:50pm |
24th Sep 2014 11:57pm |
The story so far...
30th Sep 2014 7:15am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I had a similar problem on a P38 and found that if I moved it manually and then unplugged it I had to short 2 pins to trick the ecu into thinking it was in high.
30th Sep 2014 8:57am |
I've got mine set in high mode. Just keep getting the "fail safe mode" message now... might be brave and try a high to low to high switch...!!!! Tym
1st Oct 2014 8:29pm |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
I'm tagging on to this thread after reading it , looks familiar to something I have a problem with.
15th Feb 2020 2:28pm |
Hi , this is going back a bit , I think what happened was all the sensors on each wheel were gone , most of all the pick up rings on the driveshafts, you may see some more threads on this . When I went to replace the rings , I bought aftermarket sensors and that created more problems , got a refund and ordered genuine L/R , chalk and cheese all problems disappeared!
9th Apr 2022 5:30pm |
