Home > Technical (L322) > Suspension Fault
kruger2002
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Suspension Fault
Had the 2006 4.2SC for just over a year now and recently started to get a few "bongs" which I'm hoping some of you might be able to help with.
The first is a suspension fault message, switch of and start again seems to remove the message.
Tested the raise and lower and that seems to be ok, so then switched to off road on screen and watched the wheel travel.
What I think I'm seeing is a lot of travel (on screen anyway) on the rear drivers side but little on the other wheels.
Bearing in mind this is normal commuting driving so roundabouts and long lefts/rights and not off road.
Any ideas??
Thanks in advance.
Mike Currently - 55 FFRR S/C and loving it
Post #282360 23rd Sep 2014 7:14am
its getting colder now so whats the battery condition like? ... - .- -.
Post #282375 23rd Sep 2014 7:46am
kruger2002
Stan,
Taken a while to get back into looking at the car hence the delayed response.
Battery seems fine, just showed 12.1V not running, guess thats ok?
Post #284695 6th Oct 2014 7:44pm
battery sounds ok...could be the height sensor faulty on the osr airbag...i think its best to get a diagnostic tool on it to show the errors.. ... - .- -.
Post #284707 6th Oct 2014 8:19pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
oh resurrection of this one.......every time i make a right hand turn at the same roundabout i get bong bong. Stop restart and all is ok for 24 hours until i get to this 1 particular roundabout and again bong bong. I remember reading earlier about the sensors [codes concerning abs etc etc] but cannot find it/them. Battery fine. Any thoughts?
Post #286934 16th Oct 2014 7:56pm
