![]() | Home > Technical (L322) > Swapping the battery on a 5.0 SC |
http://www.ebay.co.uk/itm/3mm-to-12mm-ALL-...256f33c0ba
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I'd agree with you Eugene, but the S5 comes in a 393mm length and this is too long once you take into account the positive terminal connection which sits down the side of the battery, taking up space. Discovery 4 HSE
It's never been mentioned Craig so I doubt it, was probably for the TDV8s with the FBH battery drain issues. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
Adam, have you been able to determine the max dimensions that do fit, so Stan can put it in the Wiki ?? MY 2010 5.0 SC Galway green and sand interior!!
As long as you replace like for like Eugene, it should all go ok. Discovery 4 HSE
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
Adam, Is the battery tray that much narrower than the 3.6? Was a squeeze to get the 020 in mine and i had to trim the side flange but it did to in even with the pyro charge. There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Might be worth asking the question Adam? ![]() |
Helios Member Since: 03 Apr 2015 Location: Epping Forest Posts: 14 ![]() ![]() |
Was there ever a definitive answer as to whether a 110AH battery can be fitted to the 5.0SC? I've searched all the threads I can find and also the WIKI but can't pin it down. RRUK says the 5.0 SC battery tray is smaller? Is that a verified fact or just his opinion? Any help appreciated, thanks |
