Home > Technical (L322) > Sat nav screen gone blank?
td6 vogue
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Guys got in the car last night and the sat nav screen is keeping the land rover loggo on all the time. Then screen goes blank and no sound,and also no blue main beam light working.Then comes back on and so does the main beam warning light. Screen is working again but has changed colour. Any one no whats wrong or had this problem. Got the car on a trickle at the moment to see if this helps???? Thanks all !!
Post #27913 12th Sep 2010 5:01pm
daveo
hi, check in the back were the nav is, they are prone to getting damp or even wet in there, best place to start, can cause all manor of silly things, as as it only just started doing it V8 facelift Range Rover Autobiography 22" wheels.
Post #27938 12th Sep 2010 8:12pm
thesuperchargerer
United Kingdom 2005 Range Rover Vogue SE Supercharged Java Black
Heres a trick: dont rush the igniton process! put the key in slowly, turn it slowly, let the music/sat nav/whichever screen start working first then turn the key to ignition. I still get caught out once in a while, dont know if its a RR thing or just a 5yr old RR thing. as you were....
Post #28006 13th Sep 2010 8:48pm
td6 vogue
Working again but colour change to the screen and no LR Logo on start up.
Any one had these problems, no one? ? ?
Post #28109 15th Sep 2010 7:22pm
daveo
hi, may be the firmware is currupt, do you not have an update disc to reload. V8 facelift Range Rover Autobiography 22" wheels.
Post #28113 15th Sep 2010 8:27pm
td6 vogue
Hi Daveo. Is it only the dealers that has this disc or do specialists do this aswell ? ?
Post #28220 16th Sep 2010 6:51pm
daveo
i have a disc, pm me where about you are.. V8 facelift Range Rover Autobiography 22" wheels.
Post #28230 16th Sep 2010 7:22pm
td6 vogue
daveo thanks for all your help,but car has been done today at a bosch specialist near to me. Very Happy Have been told that the battery is at around 50% of its true out put. Still the car is on original battery so i will see how it goes. Thanks for all posts!
Post #28314 17th Sep 2010 5:57pm
if the RR still starts on your battery dont get conned into buying a new one unless the bosch peeps can prove the battery is on its way out by doing a load test on it. ... - .- -.
Post #28316 17th Sep 2010 6:02pm
On the contrary my friend , It is quite common on FFRR's for the battery to start to fail it will still crank the motor but all sorts of electrical systems get sulky .A battery is really only good for about 4 years any thing els is borrowed time. 2008 MY Supercharged
Post #28364 18th Sep 2010 8:25am
agreed axle, but look at the bit where i say ''unless the bosch peeps can prove the battery is on its way out by doing a load test on it.'' ... - .- -.
Post #28369 18th Sep 2010 9:59am
True enough , their is a long tradition on this site of not actually reading other peoples post properly Wink 2008 MY Supercharged
Post #28396 18th Sep 2010 3:49pm
My battery must be on borrowed time 5 year and 3 month old ......... Rolling Eyes
Post #28399 18th Sep 2010 4:04pm
Winter coming Question 2008 MY Supercharged
Post #28405 18th Sep 2010 4:58pm
axle you're right about batterys going 'sulky', mines starting to do that ..the nav screen comes on really slowly instead of straight away..mind you its 5 year old and like you say ,winters a coming... ... - .- -.
Post #28413 18th Sep 2010 6:10pm
