![]() | Home > Technical (L322) > Sat nav screen gone blank? |
hi, check in the back were the nav is, they are prone to getting damp or even wet in there, best place to start, can cause all manor of silly things, as as it only just started doing it V8 facelift Range Rover Autobiography 22" wheels.
thesuperchargerer Member Since: 31 Aug 2010 Location: in a comfy armchair Posts: 7 ![]() ![]() ![]() |
Heres a trick: dont rush the igniton process! put the key in slowly, turn it slowly, let the music/sat nav/whichever screen start working first then turn the key to ignition. I still get caught out once in a while, dont know if its a RR thing or just a 5yr old RR thing. as you were.... |
td6 vogue Member Since: 31 Dec 2009 Location: essex Posts: 93 ![]() ![]() ![]() |
Working again but colour change to the screen and no LR Logo on start up.
hi, may be the firmware is currupt, do you not have an update disc to reload. V8 facelift Range Rover Autobiography 22" wheels.
Hi Daveo. Is it only the dealers that has this disc or do specialists do this aswell ? ? |
i have a disc, pm me where about you are.. V8 facelift Range Rover Autobiography 22" wheels.
daveo thanks for all your help,but car has been done today at a bosch specialist near to me. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35630 ![]() ![]() |
if the RR still starts on your battery dont get conned into buying a new one unless the bosch peeps can prove the battery is on its way out by doing a load test on it. ... - .- -.
On the contrary my friend , It is quite common on FFRR's for the battery to start to fail it will still crank the motor but all sorts of electrical systems get sulky .A battery is really only good for about 4 years any thing els is borrowed time. 2008 MY Supercharged
agreed axle, but look at the bit where i say ''unless the bosch peeps can prove the battery is on its way out by doing a load test on it.'' ... - .- -.
True enough , their is a long tradition on this site of not actually reading other peoples post properly |
My battery must be on borrowed time 5 year and 3 month old ......... |
Winter coming |
axle you're right about batterys going 'sulky', mines starting to do that ..the nav screen comes on really slowly instead of straight away..mind you its 5 year old and like you say ,winters a coming... ... - .- -.
