Home > Technical (L322) > Steering retract
Dave ray
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Steering retract
My motor on the steering has stopped working but stuck on the far setting is there a manual way of retracting it like there is on the sunroof
Post #280954 14th Sep 2014 6:14pm
Yes, three star drive screws under the steering column and drop the bottom bit off, then you will see a worm drive sticking towards you, luckily it has a slotted end, use a flat screwdriver and turn it till it's where you want it... Job done... you need a pretty long star drive to get the screws out... Pete
Post #280956 14th Sep 2014 6:32pm
Dave ray
Thanks for that just till I get it looked at
Post #280963 14th Sep 2014 6:40pm
New column is very very expensive and AFAIK you can't buy the individual bits Pete
Post #280965 14th Sep 2014 6:43pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
The parts can be sourced, I had an artical in one of my Land Rover mags about a german chap who makes either the bracket or gear at a good price. Im away at the moment not home for a week, pm me and I will look it up when I get back if you want
Post #280984 14th Sep 2014 8:42pm
Uli - "Meerbusch" on forum - though he has been quiet of late .
Post #280986 14th Sep 2014 8:44pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
@Dave ray, mostly the white plastic bracket is broken, you can buy it at around 40GBP at your official LR Dealer, easy to fix, from the side of the dashboard you can look inside, and when you have fingers like a fog, you can fix from the side, otherwise from under the steering, it is a common problem. If the plastic nut is out of order, go to ebay.co.uk, and look at my offer / advice from STEERING Range Rover L322, best wishes, Uli (if questions, ask me in clear english)
Addit 1: saw just in TV, that Scottland will out of mother GB, is there also a great RR community?
Addit 2: now beginning to repair the HITACHI compressors for the RR Sport / L322 08/05 to 09/2010 / Disco 3, not
so easy like the WABCO from 02-05.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #281007 14th Sep 2014 9:19pm
Meerbusch
@ Dear Joe90, watching the FullFatForum like a labrador-dog the meals on the kitchen table..... Wink) L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #281012 14th Sep 2014 9:28pm
That's good to hear, must have a look at mine then that won't move anywhere...... Pete
Post #281021 14th Sep 2014 9:50pm
