Home > In Car Electronics (L322) > Identify tuner
Billydun34
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Identify tuner
How can you tell the difference between a digital and analogue tuner by looking at the tuner itself? I have nothing coming on my tv and after looking in the rear passenger side I see the tuner but don't know how to get it out to check the label.
So can it be identified by plugs alone on the unit??
Thanks
Post #280798 13th Sep 2014 8:38pm
Discotigger
You should be able to read the Tuner part numbers from the front of the tuner box. If it's a digital box it may also have an additional connector port (it's a green port on my upgraded digital tuner), but not sure what connects into it. The only other way to tell is by checking the size of the box itself. The old analogue tuner box is a fair bit bigger than the digital boxes.
When you say you're not getting any tv, do you mean you're getting static? If so then you've probably got an analogue unit fitted.
My old analogue unit has the part numbers as follows:
XRA500060 and 4H43-19G212-A
My digital box has the part number:
AH42 19C063 AE
Hope that helps
Post #280902 14th Sep 2014 1:57pm
Billydun34
Thanks disco for the reply, im just about to pull the box out so i can get a look at the numbers, the connections on the tuner that is there are one green, brown, black and a white one i think but ill report back once it is out.
Post #280904 14th Sep 2014 2:02pm
We sell the Hybrid boxes sir... Send me a PM if of interest Thumbs Up
Post #281032 14th Sep 2014 11:17pm
Maxmax171
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Newbie after digital tv
Hi cam tech, sorry I can't pm you as I'm a newbie! Just purchased my second rr an 06 4.2 supercharged. Touchscreen head unit and the rear entertainment pack but , you've guessed it, only analogue TV, reading through the forum your the man to speak to, could you pm me details for digital conversion please. Many thanks
Post #309856 2nd Feb 2015 1:11am
Maxmax171
Digital tv
Well what can I say.......purchased my hybrid box from cam tech craig (many thanks) and everything works perfectly just with simply changing the tuner. Really surprised at how good the picture / reception is even when on the move. Now I say simply changing the tuner unit, it is simply changing it but don't think its a five min job. I had to resort to craig for guidance as wasn't sure if the base speaker in the rear had to come out but craig assured me it didn't and guess what he was right Bow down Basically everything in the rear "electrical cubby hole" has to come out and omg so many plugs !! But when you press the button for tv and the snow screen has gone and multiple digital channels appear... Very Happy Very Happy Rolling with laughter thanks again cam tech
Post #315478 28th Feb 2015 10:42pm
Your very welcome sir Bow down
Post #315591 1st Mar 2015 5:48pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I left the old analogue tuner in place and fixed the digital one to it with some 3M body tape, been there for a year and no problems (not with the TV at least) and I can easily remove when I come to px the FF in due course. Took about 5 -10 mins top to install There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #315670 2nd Mar 2015 11:11am
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
You got a price for the tv box Craig mine is 05 touch screen
Post #315690 2nd Mar 2015 3:13pm
