Home > Technical (L322) > How much wiggle. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Put a lever bar in behind the bush (between the bush & the subframe) and lever it (as if to squash the bush against its bolt) the arm should have 1-3mm of travel as you squash the rubber but should spring back into its original place. It will twist at the balljoint end "as thats what its designed to do" |
13th Sep 2014 11:46am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8584 |
Top man! I'll get my bar out. There is nothing that can't be fixed with a hammer😜😜
13th Sep 2014 11:52am |
13th Sep 2014 9:56pm |
