Home > Technical (L322) > Could a weak battery be the cause of this error code?
OK,
So the irony will not be lost on people who have been reading my thread about why bother having an IID tool for reading error codes! Rolling with laughter
So, today the EML light is illuminated after a cold start, repeated starts, shut downs etc and it's always there and doesn't extinguish, so I took it to my local non LR garage to have it assessed ASAP so I don't want to knacker it.
The fault codes they read were PO300, PO302, PO304, PO306 and they said it was across all cylinders (as these codes relate to "Random Multiple Misfires").
The car is driving fine and doesn't feel lumpy, no backfiring etc, and the light has stayed off now that they have cleared the fault.
I am suspicious because I know my battery is weak, if I open the doors a few times while cleaning it or whatever it's only a matter of minutes (3-5 max) before I get the message on the dash saying "Low Battery warning, please start engine". My friendly LR dealer said although it is OK, it probably is on it's way out. The battery sits at 11.8V and charges at 14.4V and on cold starts can sound quite slow.
Does anyone think that a weak battery and potential voltage issue on cold startup could have given rise to the EML and the random multiple misfires?
By the way, the Indy garage recommended changing all 8 coil packs and spark plugs at a mere £750! Shocked
(I'd rather you didn't turn round and say "you should buy an IID tool" please!) Discovery 4 HSE
Post #280139 10th Sep 2014 9:17am
Refraining from stating the obvious, so I'll state another 'obvious' reply of why not change the battery first and see what happens?
You know it's weak and it'll only get weaker as the year becomes cooler. It's an inevitable job.
Go from there. Si. <This is my name.
Post #280141 10th Sep 2014 9:22am
I already have the new replacement in the garage, just waiting for a clear few hours to do it, like to take my time on these things and do a proper job, not rushed. Will be using the Wiki. Thumbs Up Discovery 4 HSE
Post #280142 10th Sep 2014 9:28am
and the new battery is sitting at 12.7 V cold with no charge, so I know mine is below par, and you're right, I wasn't going to leave it till the winter cold snaps to see what happens Discovery 4 HSE
Post #280143 10th Sep 2014 9:29am
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
A couple of hours to change the battery Question Question
Hard core RR drivers can do it under a minute Whistle
Post #280145 10th Sep 2014 10:10am
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I put a Bosch S5 in mine a couple of years ago and it is starting to fail (just awaiting the warranty replacement). I get all kinds of random dash messages when the battery is low, e.g. HDC Not Working, ASC switched off, etc - all of which clear as soon as the car is putting the right voltage out.
Post #280146 10th Sep 2014 10:10am
ebajema
Hi Adam, I agree with Bellini, have another look once you changed the battery Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #280165 10th Sep 2014 11:52am
Sandyt
Agreed battery first then read the faults ooops but you may need a reader to do that Whistle
Post #280167 10th Sep 2014 11:57am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Battery first thing to change, you know FF's like them, I would charge up your spare new battery before fitting though to give it a full charge Thumbs Up
No tool would tell you that a battery is flat, you done that all on your own Whistle Laughing If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #280172 10th Sep 2014 1:05pm
