Home > Technical (L322) > Low on the back |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Ok quick update
9th Sep 2014 4:13pm |
Is there anybody there |
10th Sep 2014 6:08am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
" Ten Mrs Pugiewugies cutting square cut punts , they're low at the back and square at the front"
10th Sep 2014 6:19am |
Thank you for the reply
10th Sep 2014 4:54pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2576 |
You have the opposite of me
10th Sep 2014 5:00pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Steverr, HDC inactive either low battery or ecu chain of commands error. Interesting no faults registered? YOu say it droped to access height OK, did it come back up to Normal/Off Road OK? It is believed that it should take @ 1.5 minutes to go from access to off road, best we have as a test for the compressor.... .
10th Sep 2014 5:25pm |
Joe, I tried to go up to off road height but didn't wait long enough. I'll go check.
10th Sep 2014 5:52pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8524 |
Pressure will drop as you change height as its increasing the volume in the system as the air bag expands and the car goes up.
10th Sep 2014 7:57pm |
thanks for the replies |
10th Sep 2014 9:03pm |
Hi how do I test with 12v ? Is it the red/white and brown wire ? |
14th Sep 2014 4:40pm |
Yes
14th Sep 2014 5:34pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
If your getting 180psi in the tank then that's the right amount...
14th Sep 2014 5:42pm |
thank you |
14th Sep 2014 6:03pm |
Hopefully fingers crossed all sorted. there was a noise like something was loose in the compressor. One of the 3 fixing bolts was a tad loose and vibrating the compressor.
14th Sep 2014 6:11pm |
