Home > Technical (L322) > Low on the back |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
Live values of the corned heights mean nothing on their own, they can be very different, it just depends on the height sensor and they are all different... measure each corner from the center of the wheel to the top of the wheel arch, fronts should be the same, rears about 10mm lower if any are more than 10mm + or - out then you need to calibrate the system... Pete
14th Sep 2014 7:05pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7802 |
493mm front and 483mm plus /minus 3/5mm
14th Sep 2014 8:26pm |
