Home > Maintenance & Mods (L322) > More Whine ?! AC Problem |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
Its the compressor, had the same on my old one, initially thought it was viscous fan as it was rev related but went away with AC off...had it done under warranty so no idea of cost unfortunately,,. '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
6th Sep 2014 10:27pm |
Jumpy Member Since: 23 Aug 2014 Location: Surrey Posts: 14 |
Thanks for the advice -makes sense to be the compressor.
6th Sep 2014 10:55pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The compressor will whine when the gas gets low , compressors aren't that expensive but a re-gas is even cheeper but if you can get a new compressor out of the warrantee that might be better and possibly cure the micro leak ( if you have one ) 2008 MY Supercharged
7th Sep 2014 3:40am |
Cheers axle - Sounds like I might as well try a re-gas first. £50 is better than a potential £500 !!!
8th Sep 2014 9:54pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2251 |
From memory they have to pressure test the system as part of the regas so if there is a leak it will show up
9th Sep 2014 12:42pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3217 |
Unfortunately not all regassers check for a leak. Best to specify that a leak check should be done. John
9th Sep 2014 12:49pm |
THanks for the help / advice everyone.
9th Sep 2014 1:22pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 530 |
Mine whines as well, I assumed it was bearings, haven't done anything about changing it so far. I could try a gas-up and see I guess.
9th Sep 2014 1:36pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Mine has a small leak, always whines when low, stops when regassed. |
9th Sep 2014 1:38pm |
