![]() | Home > Maintenance & Mods (L322) > More Whine ?! AC Problem |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
Its the compressor, had the same on my old one, initially thought it was viscous fan as it was rev related but went away with AC off...had it done under warranty so no idea of cost unfortunately,,. '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
Jumpy Member Since: 23 Aug 2014 Location: Surrey Posts: 14 ![]() ![]() ![]() |
Thanks for the advice -makes sense to be the compressor.
The compressor will whine when the gas gets low , compressors aren't that expensive but a re-gas is even cheeper but if you can get a new compressor out of the warrantee that might be better and possibly cure the micro leak ( if you have one ) 2008 MY Supercharged
Cheers axle - Sounds like I might as well try a re-gas first. £50 is better than a potential £500 !!!
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
From memory they have to pressure test the system as part of the regas so if there is a leak it will show up
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Unfortunately not all regassers check for a leak. Best to specify that a leak check should be done. John
THanks for the help / advice everyone.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Mine whines as well, I assumed it was bearings, haven't done anything about changing it so far. I could try a gas-up and see I guess.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Mine has a small leak, always whines when low, stops when regassed. |
