Jo,
The trim clips underneath are the two part ones, pull the middle out then the outer.
It's then push clips into the face of the sill, as birchyman71 said, some will break
You don't have to take the bottom of the front wing, but it may help to pull the bottom out and release the two clips
The jacking points have a big retainer in the middle, it pulls out about 30mm then you can pull the jacking point off...
There are loads of large grommets down the sill so it would be easy to fill the cavity with your favourite rust preventer Pete
