Home > Maintenance & Mods (L322) > Rear wheel arch rust a warning
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
The cover trim is quite easy just buy some spare clips in as some will probably snap as for getting the under Neath ones out I have a trim removal set easier and less brutal than a screwdriver
Post #279026 4th Sep 2014 12:00pm
Jo,
The trim clips underneath are the two part ones, pull the middle out then the outer.
It's then push clips into the face of the sill, as birchyman71 said, some will break
You don't have to take the bottom of the front wing, but it may help to pull the bottom out and release the two clips
The jacking points have a big retainer in the middle, it pulls out about 30mm then you can pull the jacking point off...
There are loads of large grommets down the sill so it would be easy to fill the cavity with your favourite rust preventer Pete
Post #279071 4th Sep 2014 3:35pm
birchyman71
Here's the drivers side forgot to take one at the start but I've filled the holes and halfway through sanding ready for some more filler on the second pic and it's painted and clear coated on the top one I'll wet and dry it and polish it to blend it in a couple if days when it's fully gone off , as before the bit behind the trim I did with stone chip
Post #279081 4th Sep 2014 5:03pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
that's an impressive paint finish Bow down Bow down , did you use just a rattle can or a proper air gun like they have in spray shops as Ive tried in the past with a rattle can and never been pleased with the results
Post #279084 4th Sep 2014 5:25pm
birchyman71
Rattle cans , I've been surprised by how good the finish is I've just done the rear quarters on my daughters seat arosa with cans from the same place and the finish and colour match was excellent
Post #279085 4th Sep 2014 5:34pm
