![]() | Home > Maintenance & Mods (L322) > Tyres... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
not every one can afford to fork out for new pirellis or contis so these nexens are a good alternative.....
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
Yep, had them on my XC70, very good, even in the snow... Pete
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
They have just arrived and they are massive lumps of rubber!
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I spent a lot of time deciding and went for Michelins again on mine. Fronts needed replacing after 24000 miles as the edges had worn down to the chords but the rears are still going and have done 26000 miles and about half worn.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
there is a separate debate over this, but I have slowly sourced a set of four same make tyres, secondhand All with 7mm tread remaining. -one was 'new' with the full 8mm all on ebay. you can often get them at £50 each, and mostly under £100 all mine are continentals, as they are popular in Germany, where the bulk of 'part worn' tyres come from, as they have different laws regarding tyres, ie no puncture repairs, at all. and dealers fitting them in new 'axle pairs'. hence they get sent to UK and sold to us. one of mine has had a professional repair. not a bad way of saving a few hundred quid. if you do your groundwork, and check them for manufacture date etc
