Home > Maintenance & Mods (L322) > Sidestep Bracket Corrosion..... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
So, it would appear that my far too ample frame has finished off the drivers side sidestep.
2nd Sep 2014 3:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
i have a feeling that these are not OE type steps Mark as the bracket should be in one piece with the step,
2nd Sep 2014 3:27pm |
Ah. Thanks Stan.
2nd Sep 2014 3:37pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8266 |
I've still got the pair that came off mine, they are originals, they are a bit rusty but only surface, still good and strong, took my not inconsiderable weight....
2nd Sep 2014 5:58pm |
That's very kind of you Pete.
2nd Sep 2014 6:08pm |
I see you have added a pic whilst I was typing......
2nd Sep 2014 6:11pm |
PM sent Pete
2nd Sep 2014 6:18pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Mine (earliest of early cars!) are the same as stan's photos and Haylands too. .
2nd Sep 2014 8:30pm |
Well as they are no use, I sort of investigated removing the ones that are on, only to find I can't undo the bolt going into the chassis. The edges of it seem a bit corroded. Not sure how tight it is, as I can't get purchase with a socket or spanner.
5th Sep 2014 4:20pm |
I sheared the bolts off on one side (the inner ones). Was able to drill out the remaining stud, then drop a new bolt through the hole from inside the chassis boxing - LR provide suitable access holes. .
5th Sep 2014 5:04pm |
Mark,
6th Sep 2014 5:11am |
