Home > Maintenance & Mods (L322) > Sidestep Bracket Corrosion.....
mjdronfield
So, it would appear that my far too ample frame has finished off the drivers side sidestep.
I got out the car earlier and the step continued to go down when I put my foot on it.
Further investigation showed that the bracket holding it to the car was very corroded and had bent through rust when I put weight on it ;
Does anyone know if you can get the brackets separately or do I have to replace the entire sidestep ?
Poss could have a new bracket made ?
I think I'll have to get the trolley jack out and see if I can ease it back into position.....
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #278648 2nd Sep 2014 3:13pm
i have a feeling that these are not OE type steps Mark as the bracket should be in one piece with the step,
Post #278657 2nd Sep 2014 3:27pm
mjdronfield
Ah. Thanks Stan.
I think they were on it from new, but that doesn't mean they were OE ones I suppose.
I've asked Dan, so well have to see what occurs......
Might end up having some made then.
Could anyone with an early car and sidesteps have a look and see if yours look the same bracket wise ?
Could be a dodgy sidestep made in the same place as the gearbox !
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #278662 2nd Sep 2014 3:37pm
I've still got the pair that came off mine, they are originals, they are a bit rusty but only surface, still good and strong, took my not inconsiderable weight....
You are more than welcome to have them... and I'm not that far from you....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #278684 2nd Sep 2014 5:58pm
mjdronfield
That's very kind of you Pete.
I was sat here wondering what the best course of action could be.
I've used a jack and pushed it back up, but it will bend again if used.
Did yours go into the front mudflaps ?
I'm in Chesterfield, so not too far.
My Mum lived in Routh near Beverley for about 20 years, so I have been known to visit the East Yorkshire !
Do you have any pics ? Are the brackets part of the step like in Stans pics then ?
Many Thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #278685 2nd Sep 2014 6:08pm
mjdronfield
I see you have added a pic whilst I was typing......
Do you want to arrange a meet ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #278686 2nd Sep 2014 6:11pm
PM sent Pete
Post #278687 2nd Sep 2014 6:18pm
Mine (earliest of early cars!) are the same as stan's photos and Haylands too. .
Post #278715 2nd Sep 2014 8:30pm
mjdronfield
Well as they are no use, I sort of investigated removing the ones that are on, only to find I can't undo the bolt going into the chassis. The edges of it seem a bit corroded. Not sure how tight it is, as I can't get purchase with a socket or spanner.
Not tried banging a smaller socket on yet, don't want to totally stuff it up if I have to get a garage to undo them.
Pain really, they only need to be slackened off to get the bracket out.
Just my luck....
Has anyone tried them socket things that are supposed to undo worn heads ? Any good ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279266 5th Sep 2014 4:20pm
I sheared the bolts off on one side (the inner ones). Was able to drill out the remaining stud, then drop a new bolt through the hole from inside the chassis boxing - LR provide suitable access holes. .
Post #279275 5th Sep 2014 5:04pm
Mark,
Ring me Monday, we'll arrange a time, pop over and I'll sort them for you, I'll get them off.... Pete
Post #279374 6th Sep 2014 5:11am
