Home > Maintenance & Mods (L322) > solar charger |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
how easy is it to find out if you have a battery drain issue? |
27th Aug 2014 3:07pm |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
As I have posted, I have quite a few D3 and D4 customers, who have two batteries being maintained by 20w solar panels. The solar panel not only maintains the two batteries, but also replaces the power consumed by the battery isolator. The Isolator draws around 200ma, which is about 5Ah per 24 hour period and a 20w panel keeps these two batteries maintained and replaces the 5Ah used each day by the isolator, and this is in the UK, not over here in Australia. Note, this is not just a 20w panel maintaining the set up every sunny day but is doing so on an average of sunny and overcast days. Based on your “THEORY” of a 5w panel only achieving 1w, then a 20w would only achieve 4w but that just does not meet the math needed to achieve what these 20w panels are REALLY doing. So your “THEORY” that a 5w panel would not maintain a single cranking battery falls some what short of tried and proven reality. BTW, if your battery is in good condition, but as low as 11.9v, it will still start a TDV8, so it’s no surprise that your TD6 stated started with a battery voltage of 12.3v. And over here, you can start a TDV8 with a battery voltage as low as 11.5v 2007 TDV8 Lux |
27th Aug 2014 6:31pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Whilst I appreciate your endeavours to sell solar battery chargers I am somewhat concerned that your experience in Aus is somewhat clouding your expectations of solar panel output in winter in the uk.
27th Aug 2014 7:52pm |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
I just bought a ring rsp600 5w for £39 notes from amazon
27th Aug 2014 8:11pm |
Nicedayforit, do you actually read the threads you comment about. I clearly stated that TDV8s in the UK can be started from 11.9v. Next, I do not sell any form of solar panels, I have recommended that “UK” customers of mine, who have to leave the vehicle unused for long periods, fit solar panels to their D3s or D4s and quite a few of these “UK” have done so and have been using these setup for many years now. As such, contrary to your doom and gloom scenarios, which are based on nothing more the your “OPINIONS”, the info I have posted up is based on feedback from my “UK” customers, who are not having any of your mythical problems. 2007 TDV8 Lux |
27th Aug 2014 8:58pm |
Hi espaceboy, even if you drive your RR everyday, you will find your solar panel will improve your cranking battery’s condition. This will improve your starting ability but it will also help to extend the operating life span of your battery. So your panel will pay for itself. 2007 TDV8 Lux |
27th Aug 2014 8:59pm |
are you saying Im £839 up
27th Aug 2014 9:02pm |
@ drive safe.
27th Aug 2014 9:24pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Here's mine.
27th Aug 2014 9:25pm |
Just for your own interest, for all of you fitting the solar panels.
28th Aug 2014 1:42am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Look folks. A solar charger is never going to replace a normal mains powered battery charger. It will never be good enough to sort out a poor battery. What it does do though is over a long period of time help to maintain a " good" battery for those folk who leave their car for longer periods of time whilst they are at work. holiday etc.
28th Aug 2014 6:28am |
Hi appj62 and while the intention is more so to stop the battery from discharging, but as I posted above, and as long as your battery is in good condition, but just in a low state of charge, a 5w solar panel will actually charge the cranking battery, but it will take a L-O-N-G time and is why I also suggested that you will need to give it about a month before you will see noticeable improvements in a battery’s settled voltage.
28th Aug 2014 8:19am |
where can i get a connector that will allow me to connect the charger to the rear socket, i am planning on sticking it on the rear parcel shelf and the one from marlins just has a pair of crocodile clips... |
9th Sep 2014 1:52pm |
Mine came from conrad and had a cig lighter plug in as well as the crocodile clips. |
9th Sep 2014 2:05pm |
