![]() | Home > Maintenance & Mods (L322) > solar charger |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 968 ![]() ![]() ![]() |
has anyone used a solar charger to keep the battery flow going flat if left for a while.... |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I have one. Left the car for a week with a dodgy battery and it did start (just).
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi Andy and while I sell battery chargers, I regularly recommend to people in situations where a vehicle is to be left unused for long periods, to use a solar panel to charge and maintain the battery while not in use.
can you connect it to the power socket in the boot to charge? |
Yes. |
so this would help with keeping the battery healthy then? |
Yep, if you park outside, face the RR north and lay the solar panel on the rear cargo cover and it will keep the battery maintained, no matter how long you leave the RR unused.
Solar battery chargers will only maintain a battery in a charged state if the power output of the charger at any time is greater than any battery drain on the car ie a solar charger with a maximum output of say 5W can only cater for a battery drain of less than 5W. Also in the UK solar chargers will not give anything like the rated output apart from in summer, on a good day.
Mine is 15w and worked in Scotland - but it was a particularly sunny time in Scotland.
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
I have checked my car and know that the battery drain is fine, but since I sometimes go well over a month without driving it, and it is parked on the road not near a main socket, I think I'll get a 5W one of these just to keep it topped up. My normal drain is something like 50mA from memory, so even if the solar charger is only charging for 1/3 of the available time it only needs <2W to keep it topped up.
i dont suppose anyone could point me in the right direction of where i could buy a good one? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
maplins have a good range andy... ... - .- -.
Hi nicedayforit, I have quite a few D3 and D4 customer in the UK, who use solar panels to maintain their two batteries, but I recommend a 10w to 20w panel in these vehicles because there is two batteries to maintain and the power consumption of an isolator to cater for. They don’t have any problems keep their batteries in good condition, even when these vehicles are left for weeks at a time. So for a single battery situation, a 5w solar panel is more than adequate. 2007 TDV8 Lux |
Hmmm...
