Home > In Car Electronics (L322) > 2011 climate contol dash in to 2002 RR
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
One of the temperature control switches was broke when I bought the car, it works but the centre bit falls off all the time, Rolling Eyes
can I fit one of these in to my 2002 is it a straight swap i.e. plug and play or will I have to get the switch(S) out and fit them to my unit.
I have a number of the 2011 units if any one else want to try first Laughing
Post #277522 26th Aug 2014 12:28pm
Googsy
I don't believe so .You can fit a 2006 to 2009 panel though. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #277524 26th Aug 2014 12:33pm
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Will be following as looks interesting! Accept, some days your the pigeon, some days your the statue!
Post #277534 26th Aug 2014 1:48pm
hex
if people are interested in this I will try to document it here Smile
Post #277542 26th Aug 2014 2:28pm
Boydonegood
Id be well interested! Would be a nice update from my 2004! Accept, some days your the pigeon, some days your the statue!
Post #277544 26th Aug 2014 2:44pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
You've got more chance of fitting the one without climatic seat controls. Just use the Vogue one. The one you have is Vogue SE and Autobiography standard fit.
Post #277578 26th Aug 2014 6:45pm
ibb1
Also where will his air susp info go?.
Post #277651 27th Aug 2014 8:57am
as above ^, where will you put the suspension mode control,
Post #277655 27th Aug 2014 9:12am
hex
this is what I have now
and this is the new unit opened up
and the bits I have removed so far
next is to remove my panel and see if the top part fits
I have a cunning plan for the bottom half and the suspension control and info Smile ( just hope it works lol)
Post #277699 27th Aug 2014 12:24pm
Discotigger
Is it my imagination or are all the controls on that new panel in the first post the opposite way round to the ones in most peoples' FFs??
Did they (JLR) change the layout at some stage and if so, what problems would that cause when re-doing the connections/wiring?
Post #277700 27th Aug 2014 12:33pm
no you are correct DT, why they put the heated front/rear demisters on the far left initially i dont know.. ... - .- -.
Post #277702 27th Aug 2014 12:35pm
hex
got the first part done today Smile
Post #278190 30th Aug 2014 2:58pm
so you just using the knobs and not the switches then? ... - .- -.
Post #278206 30th Aug 2014 5:47pm
hex
well to start with yes
Started to take the one out of the car and found it split in to 2 parts Evil or Very Mad not 1 complete unit like the new one.
Then I got distracted and ordered a new android head unit like the one on the threads here.
I got further distracted by the wife wanting to go shopping. I took her but sat in the car and dismantled the switches on the 2011 climate control, so it wasn't a wasted trip Laughing
So now I am waiting for the new head unit before I go any further
unless I get distracted again Rolling with laughter
Post #278490 1st Sep 2014 4:45pm
Would this fit 2005-2009 dashes? Got - 2017 SDV8 Autobiography in Loire Blue
Post #278621 2nd Sep 2014 1:21pm
