![]() | Home > In Car Electronics (L322) > 2011 climate contol dash in to 2002 RR |
I don't believe so .You can fit a 2006 to 2009 panel though. Present :2008 TDV8 HSE
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Will be following as looks interesting! Accept, some days your the pigeon, some days your the statue! |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 ![]() ![]() ![]() |
if people are interested in this I will try to document it here |
Id be well interested! Would be a nice update from my 2004! Accept, some days your the pigeon, some days your the statue! |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
You've got more chance of fitting the one without climatic seat controls. Just use the Vogue one. The one you have is Vogue SE and Autobiography standard fit. |
ibb1 Member Since: 27 Sep 2013 Location: London Posts: 80 ![]() ![]() |
Also where will his air susp info go?. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
as above ^, where will you put the suspension mode control,
this is what I have now
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Is it my imagination or are all the controls on that new panel in the first post the opposite way round to the ones in most peoples' FFs??
no you are correct DT, why they put the heated front/rear demisters on the far left initially i dont know.. ... - .- -.
got the first part done today |
so you just using the knobs and not the switches then? ... - .- -.
well to start with yes
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
Would this fit 2005-2009 dashes? Got - 2017 SDV8 Autobiography in Loire Blue
