Home > Maintenance & Mods (L322) > Reservoir & Valve Block Removal |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Ongoing efforts to foil "pressure static" fault - Welshdragon's replacement of the pressure switch didn't work, so I had a look at the valve block.
24th Aug 2014 4:57pm |
I forgot to mention, I also tested resistance on a few things:
24th Aug 2014 9:33pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8149 |
Jo,
24th Aug 2014 11:32pm |
Thanks Haylands - another good tip to add to the list to try and solve this annoyance .
24th Aug 2014 11:48pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35223 |
wikified . ... - .- -.
25th Aug 2014 9:47am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
That's the wrong diagram for the pressure sensor, it shows the compressor temperature sensor and valves in the compressor. You want the next page of the manual
25th Aug 2014 7:08pm |
Oh well, it lasted a day before it faulted again. Onto the next fix .
26th Aug 2014 7:13am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Joe90...sorry to hijack, but you say that if the car is on axles stands and you deflate the susp airbags, the wheels will lift?...is that on all years as I thought that the system only allowed wheels to raise when under weight from gravity ( ie when car pushes them down)?
26th Aug 2014 7:28am |
I only had axle stands under one side of the car, and with this side wheels up on 4" blocks, so the tilt as the other side went right down may have caused this effect. That said there was no weight on the axle stands when I started to deflate and the wheels were off the blocks when finished, so there must have been a bit of "Citroen" effect going on.
26th Aug 2014 8:27am |
Got'it. Ta. Was hoping wheel swapping had got easier
26th Aug 2014 9:01am |
Jo Did you check the reed valve... could be a free fix!! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
26th Aug 2014 1:13pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
And after all that work too
26th Aug 2014 5:32pm |
@ Welshdragon
26th Aug 2014 5:37pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 800 |
when you remove the head off the wabco compressor, you should see the flat reed ( metal) valve shown below as you turn it over
12th Jun 2020 1:46pm |
