![]() | Home > Maintenance & Mods (L322) > fitting front mud flaps.. DIY or dealership? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
the bottom panels just behind the front arch has to come off to fit a metal plate which the flap bolts onto.you have to drill two hole into this panel as well.. ... - .- -.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3763 ![]() ![]() |
To find out how to remove the lower panel there is a thread on replacing the side vents/grills this also details how to remove the lower panels - easier if the doors are open 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
its the plates that i am missing..
Did you buy aftermarket versions if so they tend to send out without plates. Originally I bought these and they came without plates after contacting supplier they sent me out missing brackets. I now have original oem flaps. Present :2008 TDV8 HSE
thanks for the info ..
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
If the side panels have never been removed, it'll take a fair amount of effort to get them off, so you need to be a lot braver than you think! |
