Home > Maintenance & Mods (L322) > Exhaust heat sheild
SO3isme
Exhaust heat sheild
The heat shield over my rear exhaust box is just resting on the box as all the fixings have failed. Has anyone done a repair of this issue - aside from replacing the shield and all fixings with new?
Post #277030 22nd Aug 2014 7:29am
Yes, had the same problem. Just found some suitable screws and washers, and I used a strip of perforated metal as well just to help hold everything in place where the "holes" were too big for the fixings. .
Post #277037 22nd Aug 2014 8:07am
Some of these 50mm dia washers with the original fixings would work.
http://www.ebay.co.uk/itm/STEEL-REPAIR-PEN...2ecf2eab1a
Post #277041 22nd Aug 2014 8:28am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I second that suggestion. And keep any extra washers for when you have to fix the brake disc heat shields Wink
Post #277043 22nd Aug 2014 8:49am
^+1 Thumbs Up
Post #277044 22nd Aug 2014 9:03am
SO3isme
Thanks chaps - sounds good.
Post #277049 22nd Aug 2014 9:14am
Weegie
Ressurecting this thread, I have the same problem with the rear heat shield fixings rusted away. Can't quite see where the bolts exit inside the boot area. Any pointers would be appreciated.
Ta in advance. John
GAP iiD BT
Post #296279 1st Dec 2014 12:00pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Mine was the same, it's currently lying on the garage floor, has been for the last 3 years. Not gone up in flames so all good! Mr. Green
Post #296292 1st Dec 2014 2:07pm
Weegie
Mr. Green John
GAP iiD BT
Post #296293 1st Dec 2014 2:08pm
SO3isme
I have yet to do this job but it is on my list..... Does anyone know the correct name for this shield over the rear exhaust box?
Thx.
Post #305335 15th Jan 2015 5:49pm
Mr Tee
Just a guess but maybe "rear exhaust shield'. Think you answered you own question! Mr. Green Mr. Green
Post #305419 15th Jan 2015 10:50pm
SO3isme
There seemed to be very little reference to that search term on google so I wondered if I was looking for the wrong thing.
Post #305437 16th Jan 2015 7:39am
SO3isme
I had a look. I can see that the fixings are some type of self tapping screw. Strangely, I can't find the head of the screw in the spare wheel well? Any clue? Are they just pushed up into the underside?
Post #305529 16th Jan 2015 1:20pm
They should be studs that stick down from the main body and a clip or nut screws onto them. If the studs are not there you need to devise a plan B Shocked
Post #305631 16th Jan 2015 7:46pm
SO3isme
It's definitely a screw sticking down. There is no sign of the part that holds the shield - it seems to have corroded away.
Post #305640 16th Jan 2015 8:24pm
