![]() | Home > Maintenance & Mods (L322) > Exhaust heat sheild |
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
Thanks. That sounds like a good plan B. Did you remove the old fixings? |
Finally done this job using some aluminium discs bought on an internet auction site for about 25p each. I treated the rather corroded fixing points. I then drilled out a centre hole in the discs and fixed them onto the existing screws. I made a couple of cuts to help screw them on.
