Home > Technical (L322) > Deployable Side Step Button
countryboy
2007 Range Rover Vogue SE TDV8 Stornoway Grey
Afternoon all,
I've got a relatively new TDV8 (2007 Vogue SE) with deployable side steps. The steps operate fine when locking/unlocking and opening the door. However, the roof button (near the sunroof button) doesn't work, when pressed it doesn't move the steps.
Any ideas?
Cheers, CB
Post #276047 16th Aug 2014 1:24pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
As with many things Range Rover related the operation of the steps is not as simple as you might think. I have this saved as a note on my phone to remind me how the switch works:
RR Sidesteps Operation
To force the steps to stay out regardless of the position of the doors, what LR call 'roof access and jacking mode' get in the vehicle and close the doors, quickly insert the key in the dash and turn to position two, whilst steps still out, then hold the switch for about five seconds until the light in the switch illuminates continuously then remove the key. The steps will now stay out regardless of the position of the doors unless you drive away or lock the vehicle at which point they will return to their normal function. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #276048 16th Aug 2014 1:27pm
countryboy
Cheers, tried that to no avail!
Post #276051 16th Aug 2014 1:41pm
JAYBOY
Hi try this
Start the car and put it to off road height.
Press the roof button and side steps will come out.
turn off key and they should stay out
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #276058 16th Aug 2014 4:32pm
countryboy
Cheers, will let you know! 2007 RR Vogue SE TDV8
2003 RR Vogue TD6
Post #276129 17th Aug 2014 7:40am
