Home > Maintenance & Mods (L322) > EAS Front Right Height Sensor - Connector Loose/off? SORTED!
TimP
England 2005 Range Rover Vogue Td6 Java Black
Wife comes home reporting "Air Suspension Inactive" message and EAS locked at standard height (light on in middle of control switch).
I (general numpty) have a look - confirm she is indeed correct - and also when bringing up 4X4 info screen, it shows flashing red mark under front drivers wheel which on screen is lower than others - although in reality it's at standard height.
I crawl under and fiddle around with front height sensor arms - passenger side responds - drivers side does not and I pull at the connection with height sensor and it is loose - pulls right off with no clicks and I just can't seem to get it to go back on properly.
At least I think I have found the problem - i.e. height sensor electrical connection come loose - but how the hell do they go back on... and stay on??????
Pushing hard on it / pinching sides while pushing....I have exhausted the possibilities my little brain can come up with, but it just won't go back on.
PLEASE CAN ANYONE HELP.... An old man is getting very frustrated and feeling foolish!!!!
Thanks
Tim[/b]
Post #275658 13th Aug 2014 3:12pm
Probably the clip which holds the plug in place that has broken.
Cable ties should hold it fast Thumbs Up
Post #275668 13th Aug 2014 4:04pm
TimP
Thanks for that....
I'll have a further look and go this afternoon....but it just didn't feel like a connection was being made when pushed together.
I presume EAS fault will clear when fixed.........???? !! Question
Post #275744 14th Aug 2014 10:14am
TimP
Just had a further frustrating session with this..... Rolling Eyes
It is just a push on connection with clips on either side which hold over projections on receiving connection. Everything including clips are present, but it just will not push on !!! Crying or Very sad
Maybe receiving pins have become out of line - they look straight...
Ah well... looks like I'll have to go to local indy for help.
B Censored er!!
Post #275769 14th Aug 2014 12:59pm
markcartlidge
Get a small needle or similar and just check there is nothing wedged inside the connector crimps inside the housing.
Post #275774 14th Aug 2014 1:35pm
TimP
Inside connector is like a concertina - when connecting air pressure builds and resists the push -
Local indy pushed- grunted -tugged & pushed and Bingo!.
As he said "Brute Strength and Ignorance" Qualities I thought I had in abundance ! But now have to realise as I get older ....just Ignorance Rolling Eyes Embarassed Embarassed
Any way , once back on - fault cleared - oh the joy of "bong-less" switch off in a fullfat !! Laughing
Tim
Post #275790 14th Aug 2014 2:17pm
