Home > Technical (L322) > 5.0 SC Juddering 1500-1800rpm -torque converter
rocksteadyeddie
We have a 2010 MY FF 5.0 SC which has covered about 59,000 miles. The last couple of days it has started juddering. This seems to happen between 1500-1800 rpm. It clears under harder acceleration, or as the revs rise, or if the 'box kicks down. It feels a little like driving over a cattle grid (as described elsewhere).
I have read a number of threads on here, and elsewhere, about the problem. Most of these seem to point towards the torque converter being on its way out. Couple of questions if you would be so kind:
1) does this sound like a sensible diagnosis?
2) presumably replacement is the "best" solution? How much might I expect this to cost?
3) how much might a reconditioned TC cost? Any recommendations for a specialist in North London /South Herts/Bucks?
TIA
Post #275078 9th Aug 2014 12:41pm
just wondering if changing the TC oil would help, slightly cheaper than replacing it.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #275080 9th Aug 2014 12:53pm
Vogue
Blimey, And we all thought the TD6 had gearbox issues, the S/C seems to be even worse given the speight of gearbox problems that are suddenly popping up. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #275081 9th Aug 2014 1:27pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I would check your transmission fluid level first before condemning anything. Probably worth doing a transmission fluid and filter change at that mileage anyway. TC problems only usually appear at around 50mph or above when the lock up clutch comes into play.
Post #275117 9th Aug 2014 9:14pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
My 4.2 does this intermittently, and has done for 45k miles over 2.5 years. I've had the trans fluid done several times and for me the fix is usually an IIDTool gearbox adaption reset, followed by telling the wife to stop driving my FF (or at least driving it like an old dodder).
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #275148 10th Aug 2014 11:01am
please tell me more re the gearbox reset with the iidtool mr pie... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #275153 10th Aug 2014 11:39am
mzplcg
Clearing the adaptives Stan. The ECU on the 6HP28 learns a driving style and it's this bit that gets cleared.
Post #275190 10th Aug 2014 3:49pm
TheAllSeeingPie
Yup that's the one. Engine adaptions is good to clear too after cleaning or replacing sensors or air filters.
Post #275244 10th Aug 2014 9:48pm
so clearing gearbox/engine adaptations does no harm then...i'm confused as its said in this thread that a reset will cause problems,or am i reading it wrong,
http://www.fullfatrr.com/forum/topic10417....daptations ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #275249 10th Aug 2014 9:57pm
TheAllSeeingPie
Never had a problem so far ...
Post #275252 10th Aug 2014 10:00pm
rocksteadyeddie
Thanks chaps. A friendly dealer has it in overnight for diagnostics. I am braced for their findings...
Post #275390 11th Aug 2014 9:15pm
rocksteadyeddie
Apparently there was a vacuum hose that had come undone. Reconnected and £200 later its fixed by all accounts. If it really is fixed I don't begrudge the £200 given some of the other nightmare scenarios.
Post #275558 12th Aug 2014 9:52pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Result if that's what it was. Thumbs Up
Keep us posted!
Also infuriating though. How does a vacuum hose come undone?! Sometimes, it's like bring back to the days of taking delivery of an SD1 Rolling Eyes 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #275567 12th Aug 2014 10:02pm
