Home > Technical (L322) > 5.0 SC Juddering 1500-1800rpm -torque converter |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35246 |
just wondering if changing the TC oil would help, slightly cheaper than replacing it.. ... - .- -.
9th Aug 2014 11:53am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3730 |
Blimey, And we all thought the TD6 had gearbox issues, the S/C seems to be even worse given the speight of gearbox problems that are suddenly popping up. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
9th Aug 2014 12:27pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
I would check your transmission fluid level first before condemning anything. Probably worth doing a transmission fluid and filter change at that mileage anyway. TC problems only usually appear at around 50mph or above when the lock up clutch comes into play. |
9th Aug 2014 8:14pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
My 4.2 does this intermittently, and has done for 45k miles over 2.5 years. I've had the trans fluid done several times and for me the fix is usually an IIDTool gearbox adaption reset, followed by telling the wife to stop driving my FF (or at least driving it like an old dodder).
10th Aug 2014 10:01am |
please tell me more re the gearbox reset with the iidtool mr pie... ... - .- -.
10th Aug 2014 10:39am |
Clearing the adaptives Stan. The ECU on the 6HP28 learns a driving style and it's this bit that gets cleared. |
10th Aug 2014 2:49pm |
Yup that's the one. Engine adaptions is good to clear too after cleaning or replacing sensors or air filters.
10th Aug 2014 8:48pm |
so clearing gearbox/engine adaptations does no harm then...i'm confused as its said in this thread that a reset will cause problems,or am i reading it wrong,
10th Aug 2014 8:57pm |
Never had a problem so far ...
10th Aug 2014 9:00pm |
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 |
Thanks chaps. A friendly dealer has it in overnight for diagnostics. I am braced for their findings... |
11th Aug 2014 8:15pm |
Apparently there was a vacuum hose that had come undone. Reconnected and £200 later its fixed by all accounts. If it really is fixed I don't begrudge the £200 given some of the other nightmare scenarios. |
12th Aug 2014 8:52pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Result if that's what it was.
12th Aug 2014 9:02pm |
