Home > Maintenance & Mods (L322) > Battery booster pack advice |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
8th Aug 2014 8:15pm |
jj2908 Member Since: 12 Jan 2014 Location: UK Posts: 39 |
Thanks joe. I was thinking more of the batter booster packs that you can charge up and take with you? |
9th Aug 2014 9:31am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
This one does the job on my 3.6 TDV8 on a cold morning...weighs a bit but hay'ho
9th Aug 2014 10:14am |
@ jj
9th Aug 2014 10:37am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 610 |
Only if you haven't left it plugged into the car to charge when you're in the process of flattening the battery... |
9th Aug 2014 4:18pm |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 |
Yep, that maplin one worked for me when my last battery was on its way out... |
16th Aug 2014 8:27am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8617 |
Just get a long fat set of jump leads, they will suffice in most situations...... And you don't have to remember to charge them. There is nothing that can't be fixed with a hammer😜😜
16th Aug 2014 8:31am |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
I go along with northernmonkeyjones on this one. Jump leads are an essential.
18th Aug 2014 7:54pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8269 |
If your working underneath you should leave a door open, it will stop the suspension deciding to self level... Pete
18th Aug 2014 8:53pm |
I would advise never to work under the vehicle without axle stands. My opinion. |
18th Aug 2014 9:37pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
^+1, NEVER rely on the air suspension to prevent you from being crushed!! 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
19th Aug 2014 10:01am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
For something truly portable and with many uses besides jump starting, try an Anti-Gravity Battery.
19th Aug 2014 10:29am |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
I've started getting interesting in RC stuff - mainly multirotors.
19th Aug 2014 11:49am |
