Home > Technical (L322) > 2003 FFRR TD6 - Message |
davemfox Member Since: 31 Jul 2010 Location: Chester Posts: 43 |
Hi,
8th Sep 2010 11:51am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
From the handbook.
8th Sep 2010 12:39pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Ref - IanV8's reply... Oops! - sorry dave, I could be wrong? I thought the HDC and Air Suspension were connected in some way? If the HDC Inactive message pops up, doesn't this automatically drop the suspension height? Edit davemfox - have a look at this earlier fullfatrr.com thread about the same thing... http://www.fullfatrr.com/forum/post7636.html |
8th Sep 2010 1:04pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 223 |
In theory, you have a problem with your suspension. In practice, you almost certainly have a problem with your battery, ie. it's on it's last legs. My 4.4V8 started doing this and six months later I had to replace the (original!) battery. Never had the problem since.
8th Sep 2010 3:13pm |
this worked Must have been lack of use. I'll bear the battery aspect in mind JW911 Dave 1993 YZF 750 SP |
8th Sep 2010 3:22pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi i get this some times, not that oftern but i think its one of them gremlings, did it go when you switched it off and then on, if so dont worry my mate gets it at least once a week and he never had a prob with his car. V8 facelift Range Rover Autobiography 22" wheels.
8th Sep 2010 4:29pm |
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 |
HDC Inactive would display when switch is activated to show it is not working - if it comes up when ignition starts, part of system checks, then disappears then I would say 'JW911' is correct, and low volatge is causing the phantom warning. Worth checking battery leads are tight!
8th Sep 2010 6:06pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Mine comes up regular, Recent OE spec Battery. The message disappears in seconds and no Arrows to show a persistant fault. HDC works fine to.
9th Sep 2010 3:41pm |
Cheers for your help gents
10th Sep 2010 11:06am |
