Home > Camping, Caravanning and Holidays > Sanef Tolling Liber-T |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
Use one on the annual pilgrimage to Le Mans - have mine (as instructed) pretty near to the rear-view mirror. Never had any issues at all - drive up slowly, wait for the beep and then boot it (once the barrier is up...)
2nd Aug 2014 8:23pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7967 |
Mine's right behind the rear view mirror where I can't see it whilst driving - works perfectly |
2nd Aug 2014 8:42pm |
Greg66 Member Since: 10 Nov 2010 Location: London Posts: 84 |
Yep - I went through exactly the same worry, but there's no need. Place the bracket close to the rear view mount, nice and high, and it will be fine. You will have anxiety at the very first toll, but after that, nail the "30" lanes, shouting "Sayonara, losers!" out the window as loudly as you can.
2nd Aug 2014 10:03pm |
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 |
Mine is up behind the mirror also, work like a dream all the way down to Cannes last month.
2nd Aug 2014 10:05pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
+1 Mine is APRR - the Southern Auto Route company that offer a service via credit card auto debit. I stuck it to the right side of the mirror. Never fails.
3rd Aug 2014 6:19am |
Good to know - I only did this once & just held the badge up in my hand at each booth - it worked fine, but a holder would be better. Mine is also APRR - had it ages & they were the only ones that would let you use a UK credit card - until Sanef joined up with Eurotunnel to offer them more broadly. I keep expecting the battery to fail, I guess I should really get the unit changed at some point. |
3rd Aug 2014 7:33am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8671 |
Used mine to lemans, and just got back with the tin tent from Normandy.
3rd Aug 2014 7:42am |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 |
Top left side of the window. so passenger side for rhd cars. Remember to take the item out of the clip if parked, you will not be the first one with a smashed window and a stolen quick pass.
3rd Aug 2014 1:58pm |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 |
Excellent, all good stuff guys, thank you all so much for the help and advice, certainly relaxed about it all and looking forward to the trip even more now
3rd Aug 2014 7:09pm |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
I regularly drive to Morzine in the French alps and can set you mind at rest on two counts, firstly the Sanef rag mounted behind the rear view mirror as everyone says is a really great help for the drive down, saves at least 1/2 hour, prob more on our drive and also saves waking the passenger up when they are asleep as you approach the booth.
3rd Aug 2014 9:00pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Had a Sanef one then changed for Alis. There was an additional small charge at the time if using Sanef also there was no deposit (since changed I believe) with Alis.
5th Aug 2014 11:26am |
Hi Weegie,
5th Aug 2014 12:11pm |
top tip.......
5th Aug 2014 3:39pm |
Oh okay I'll do that on the basis that if I've got it I will not need it..............I guess that's what you did then, had some with you and didn't need to use it |
5th Aug 2014 4:00pm |
