![]() | Home > Technical (L322) > Brake problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
brake bleeding procedure is on page 387 of the WM ....
Reo Member Since: 01 Jul 2012 Location: glasgow Posts: 11 ![]() ![]() ![]() |
Thanks stan i will have a read PS I would have thought kwik fit should know how to do this |
I wouldn't trust Kwik-Fit to put air in my tyres let alone change my brakes |
depends who you know that works in kwik fit... ... - .- -.
True true 47p2 live and learn |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
It is completely normal for the pedal to be a bit spongy until the new brake pads have had a few hundred miles or so to bed in fully
Oh I didn't know that Mikey thanks I was going to go back there tomorrow and kick off |
I've never had a spongy pedal after changing pads and discs. Yes the braking might not be as powerful when first fitted as they need to bed-in but never a spongy pedal ![]() |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Reo, I wouldn't expect them to be too spongy, maybe a tad, give them a good 'emergency stop too see how they are. Doesn't sound normal IMHO, keep an eye on it, but I do have to agree that Kwik Fit is not he best, if you want to know the best indys around Glasgow, let me know or do a search, There are lots of us in the area and have experienced most of it |
The other thing to try is to find a hill (no traffic) and put HDC on then set off down the hill and "let go". This will activate HDC/ABS and jiggle the solenoids in the ABS module. (not my tip!)
Thanks Rosco I'm going down to Berwick on Friday for the weekend I will see how they perform or not !!! HI joe just seen your response will give this a go in the morning thanks again |
Depends which brand of pads were used. If they were a cheaper option, they will take longer to bed in, than say, a genuine set of pads. Being Kwik Fit, I think it's safe to assume the former It will also take longer to bed in a set of new pads on old discs. A few heavy stops should do 90% of the bedding in |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Pads will take a while to bed in, but the pedal should not feel spongy - your brakes probably need bleeding, and I would go back to Kwik Fit and get them to do it for you (and thereafter avoid them like the plague - any decent mechanic will not work for kwik Fit / Halfords etc when the money is better at a main stealers.) |
Mikey no issues with the pads and discs as they are genuine brembo bought from advanced factors. Anyway took the beast back to kwik fit today he re-bled the brakes but it's still the same he is now saying he does not have the right diagnostic equipment for my model year he only has it for the 2011 model. I then did what Ray said and tried that it's a little better thanks Ray but still not right is it really that hard to bleed these brakes. |
