Home > Technical (L322) > Brake problem
Reo
Scotland 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Brake problem
Hi just got new pads and discs fitted all-round and rear callipers on 2008 range rover but the brake pedal feels very spongy I don't know if they have Been bled properly is there a certain procedure on how to do this any help welcome thanks. Thumbs Up
Post #273612 30th Jul 2014 1:25pm
brake bleeding procedure is on page 387 of the WM ....
WM download link is in the wiki.. ... - .- -.
Post #273615 30th Jul 2014 1:58pm
Reo
Thanks stan i will have a read PS I would have thought kwik fit should know how to do this Censored .
Post #273623 30th Jul 2014 2:57pm
I wouldn't trust Kwik-Fit to put air in my tyres let alone change my brakes
Post #273645 30th Jul 2014 5:41pm
depends who you know that works in kwik fit... ... - .- -.
Post #273649 30th Jul 2014 6:03pm
Reo
True true 47p2 live and learn Big Cry
Post #273691 30th Jul 2014 9:31pm
Mikey
It is completely normal for the pedal to be a bit spongy until the new brake pads have had a few hundred miles or so to bed in fully
Post #273699 30th Jul 2014 10:09pm
Reo
Oh I didn't know that Mikey thanks I was going to go back there tomorrow and kick off Whistle I take back what I said about kwik fit Thumbs Up
Post #273700 30th Jul 2014 10:21pm
I've never had a spongy pedal after changing pads and discs. Yes the braking might not be as powerful when first fitted as they need to bed-in but never a spongy pedal Shocked
Post #273701 30th Jul 2014 10:23pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Reo, I wouldn't expect them to be too spongy, maybe a tad, give them a good 'emergency stop too see how they are. Doesn't sound normal IMHO, keep an eye on it, but I do have to agree that Kwik Fit is not he best, if you want to know the best indys around Glasgow, let me know or do a search, There are lots of us in the area and have experienced most of it Thumbs Up
Post #273704 30th Jul 2014 10:34pm
The other thing to try is to find a hill (no traffic) and put HDC on then set off down the hill and "let go". This will activate HDC/ABS and jiggle the solenoids in the ABS module. (not my tip!)
Would also still suggest it is worth telling Kwik Fit you think there is a problem, rather than leaving it for a while to "bed" in. The pedal should be solid not spongy. .
Post #273707 30th Jul 2014 11:00pm
Reo
Thanks Rosco I'm going down to Berwick on Friday for the weekend I will see how they perform or not !!! HI joe just seen your response will give this a go in the morning thanks again Thumbs Up
Post #273708 30th Jul 2014 11:05pm
Mikey
Depends which brand of pads were used.
If they were a cheaper option, they will take longer to bed in, than say, a genuine set of pads. Being Kwik Fit, I think it's safe to assume the former
It will also take longer to bed in a set of new pads on old discs. A few heavy stops should do 90% of the bedding in
Post #273726 31st Jul 2014 6:40am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Pads will take a while to bed in, but the pedal should not feel spongy - your brakes probably need bleeding, and I would go back to Kwik Fit and get them to do it for you (and thereafter avoid them like the plague - any decent mechanic will not work for kwik Fit / Halfords etc when the money is better at a main stealers.) Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #273761 31st Jul 2014 9:55am
Reo
Mikey no issues with the pads and discs as they are genuine brembo bought from advanced factors. Anyway took the beast back to kwik fit today he re-bled the brakes but it's still the same he is now saying he does not have the right diagnostic equipment for my model year he only has it for the 2011 model. I then did what Ray said and tried that it's a little better thanks Ray but still not right is it really that hard to bleed these brakes. Big Cry
Post #273822 31st Jul 2014 7:56pm
