![]() | Home > In Car Electronics (L322) > 2005 touchscreen unit not working |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
Also, I have seen a screen on Ebay but the buttons are different!
Just a slightly newer unit , the changes from icons to words about 2008. 2008 MY Supercharged
ppcsl Member Since: 12 Sep 2012 Location: Ellon, Aberdeenshire Posts: 107 ![]() ![]() ![]() |
Hi Rich I seem to remember reading on this forum or one of the other Land Rover ones that if the sat nav unit is faulty then it can bring the whole system down. You would need to do a search. The fact there is no red light from the front of the fibre optics does tend to indicate it is something at the front of the setup that is faulty. Or a break in the cabling somewhere. A normal fibre optic cable tester can test for this in a computer network environment but I don't know if there is a tester available to the public for the car setup. What you can do is take the sat nav unit out and locate the fibre cable and shine a strong light down it and check the rear connector and see if it is lit. You would need to check the rave manual for the wiring route to see where it starts and ends so you know you are checking the correct cabling. The cable may feed to another device first so the light won't get to the back. It is a very slow and labour intensive operation.
Never thought about shining a light through it haha.
Yes Rich an old IT trick, showing my age now lol. It is cheaper and quicker than setting up the £1k plus fibre tester. Just for checking for breaks or bad terminations. Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold. |
Right....
Hi Rich, your not having much luck with the sound system. The issue my car had was with the amp, it didn't look as if it had been damaged by water but it was faulty. I changed it for a second hand one and it worked for a few months. Then it happened again, as I said in a previous reply I haven't got to the bottom of my cars issues. I did buy an IIDtool and it did read a couple of amp faults. I will be buying another amp as soon as I get time or trying to get one of the faulty ones repaired.
Think i'm going to cut my loses haha. It's already one thing after another with this car. Was hoping to be able to tidy it up and be happy with it but it seems like it could be £1000+ just to sort the stereo out which I'm not prepared to pay. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
Where abouts are you, perhaps someone shedding another pair of eyes on it may help...?? Pete
Luton. Don't mind travelling.
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Mark at www.vehiclecraft.co.uk is worth calling for a quote.....he's mobile and lives your way..... 2006 4.2 SC
I don't blame you Rich, I have spent £5000 plus in the last year on various things that have broken. I still have to fix the sound system again. Will be driving my car for the first time in about three weeks tomorrow and I am wondering if it is going to throw any new things at me. I had to start it today and get the suspension to pump itself up it had decided to go to sleep at the front. |
Car is now sold.
I bet that's a relief! Just out of interest how did you sell it without the stereo working? 2006 4.2 SC
