![]() | Home > In Car Electronics (L322) > tv fitment? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
should have the hybrid tuner fitted |
Capers Member Since: 07 Jan 2013 Location: manchester Posts: 14 ![]() ![]() ![]() |
thank you stan, what exactly is a hybrid tuner and more to the point is it digital and will it work without being tweaked etc.
a hybrid tuner is a combination of the old analogue and the new digital so not tweaking needed and depending on signal strength you will get a picture. |
Thank you sir am I also correct in thinking on a 08 the vogue se standard spec is lower than the vogue ? |
'se' spec is usually better than the vogue spec unless the standard vogue had extra options fitted.. ... - .- -.
Thanks for that I thought they were lesser until 2009 for some reason |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
Cooled seats are standard in the SE Got - 2017 SDV8 Autobiography in Loire Blue
