Home > Technical (L322) > Split turbo hose - TdV8 - can I drive ? |
ksskaret Member Since: 27 Oct 2013 Location: Tromsø Posts: 73 |
Just found out that I have a split turbo hose after receiving the fault message "limited performance" and the fatty ant into limp home mode. I am 600 km from home and not sure if I can find a replacement hose up in northern Norway.
27th Jul 2014 6:14pm |
Thanks Alistar
27th Jul 2014 7:00pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7922 |
2000 rpm
27th Jul 2014 7:16pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
As long as its sealed up it should be fairly ok. Plenty of duct tape will help! There is nothing that can't be fixed with a hammer😜😜
27th Jul 2014 7:19pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Yes should be ok as said don't skimp on duck tape the more the better Present :2008 TDV8 HSE
27th Jul 2014 8:22pm |
Did you get home OK ?
8th Aug 2014 8:11am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Me too Alistair, convinced myself it was the gearbox/torque converter as I was getting a judder at 1800rpm
8th Aug 2014 10:52am |
I sealed the hose up with duct tape and it worked But I also godt a local tip to visit a hydaulic workshop nearby. Tough they normally services huge craines and excavators they put a mecanic on it.
8th Aug 2014 2:21pm |
8th Aug 2014 2:46pm |
