Home > In Car Electronics (L322) > 2005 touchscreen unit not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
fuse gone or maybe water ingress in the rear near side cubby hole .. ... ... - .- -.
18th Jul 2014 8:04am |
If it has the MOST system already (my 05/05 built MY 2006 SC has the MOST) then it could be that. If one unit in the daisy chain is done (on mine the BT module) the entire system is out.
18th Jul 2014 8:05am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Could be water damage to the bluetooth unit , not uncommon, after that it gets more complicated and therefore expensive " not working " is a touch vague . But first look for evidence of water in the spare wheel well and on top of the phone unit ( it's the nokia branded box on top of the large stack of units in the near side rear compartment , this will be a start .
18th Jul 2014 8:09am |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 |
Ok thanks, It's a 55' plate so touch screen sat nav etc.
18th Jul 2014 8:13am |
Right, one of the fuses had blown so I replaced that and straight away the screen lit up with the LR logo screen but after 10 seconds or so, it just went blank.
18th Jul 2014 6:59pm |
Have just tried the cables facing each other on the nokia module but still isn't working.
18th Jul 2014 9:04pm |
I unplugged the tmc module and plugged it back in and the LR logo came on for a few seconds again.
20th Jul 2014 8:21am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Rich, when you unplug one of the fibre optic plugs, do you have a red light on one side? If no red light, no power
20th Jul 2014 8:31am |
Red light? On the power button?
20th Jul 2014 8:40am |
Read it again Rich, do you have a red light inside the fibre optic lead? OK, open boot, unplug a fibre optic lead from one of the plugs (anyone it does not matter) do you see a red laser light? If so, you need to jump the plugs one at a time..... Simples
20th Jul 2014 8:48am |
Ah. Just had a look. No red light on any of them. |
20th Jul 2014 9:06am |
Right, when I unplug and plug back in the TMC module, the logo comes up on the screen and I've just noticed that for that short time, there is a red light coming through the optic cable. As soon as the screen goes off, so does the red light. (It was flashing if that makes a difference) |
20th Jul 2014 5:53pm |
Also just wanted to mention, on my diagnostics from LR there are a couple of mentions about the battery;
20th Jul 2014 6:35pm |
Low battery voltage is always a problem with FFRRs and many other modern cars. So make sure you have a good battery and alternator and when playing with the engine off put a charger on to make sure the voltage stays well up. MY 2010 5.0 SC Galway green and sand interior!!
21st Jul 2014 5:36am |
