Home > Technical (L322) > Loss of power when engine is hot |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I'm no expert but it may be worn pumps or failing injectors. A leak off test on the injectors should let you know if any individual injector is playing up. Plugging in to a Landrover computer should tell you if there is a fuel pressure problem.
26th Aug 2010 5:20pm |
nielsen Member Since: 26 Aug 2010 Location: Sweden Posts: 7 |
Just tryed changing the airfilter today. Took it out for a spin. Engine cold max rpm 3500 and after 5 minutes when the engine got warm it changed to max rpm 2000. Just don't get it.
1st Sep 2010 3:42pm |
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 |
Is it the same in sport mode ? do you have the same problem if you pull over switch off and then start the car again ...? |
2nd Sep 2010 12:05pm |
Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 49 |
Turbo??
2nd Sep 2010 3:33pm |
It is the same in sport mode. Have also tryed turning dsc off.
2nd Sep 2010 3:54pm |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 |
high pressure fuel pump next to fuel tank 2002 td6 vogue, 06 supercharged facelift
2nd Sep 2010 6:17pm |
It sure was the fuel pump. Thanks for all your help Regards,
11th Sep 2010 9:07am |
nice to see its fixed 2002 td6 vogue, 06 supercharged facelift
11th Sep 2010 10:29am |
