Home > Technical (L322) > Loss of power when engine is hot
nielsen
Sweden 2004 Range Rover Vogue Td6 Giverny Green
I have a Range Rover '04 TD6. The last week I have had trouble getting the car to accelate to more than 3500 rpm when cold and 2000 rpm when hot which results in topspeed of 60 mph Sad
I have tryed dismounting the Mass Air Flow Sensor but that did not change anything.
Now I have orderet a new fuelfilter and airfilter.
Anyone have any idea what the problem is? Regards,
Peter
'04 Range Rover TD6
Post #26495 26th Aug 2010 5:46pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I'm no expert but it may be worn pumps or failing injectors. A leak off test on the injectors should let you know if any individual injector is playing up. Plugging in to a Landrover computer should tell you if there is a fuel pressure problem.
I wonder if its being strangled by the EGR coaking up the manifold? A search of BMW forums for the M57 engine may produce users with similar problems in the past.
Post #26499 26th Aug 2010 6:20pm
nielsen
Just tryed changing the airfilter today. Took it out for a spin. Engine cold max rpm 3500 and after 5 minutes when the engine got warm it changed to max rpm 2000. Just don't get it.
Should I be able to see any OBDII codes when I don't get any faults in the display inside the car? Regards,
Peter
'04 Range Rover TD6
Post #26985 1st Sep 2010 4:42pm
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Is it the same in sport mode ? do you have the same problem if you pull over switch off and then start the car again ...?
Post #27075 2nd Sep 2010 1:05pm
Captain Slog
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Turbo??
_________________
Currrent: 2005 FF Range Rover L322 Vogue TD6
Gone: 1999 Range Rover P38 HSE TD6
Gone: 1985 Land Rover 90 SWB diesel
Post #27099 2nd Sep 2010 4:33pm
nielsen
It is the same in sport mode. Have also tryed turning dsc off.
Today though I got an error in the display for the first time. Fuel injec. system and then 2 min. later the car stopped....of course in the midle of a tunnel Sad After a few minutes I was able to start again and crawl back home. The car is off to the work shop tomorrow... Regards,
Peter
'04 Range Rover TD6
Post #27100 2nd Sep 2010 4:54pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
high pressure fuel pump next to fuel tank 2002 td6 vogue, 06 supercharged facelift
Post #27113 2nd Sep 2010 7:17pm
nielsen
It sure was the fuel pump. Thanks for all your help Smile Regards,
Peter
'04 Range Rover TD6
Post #27828 11th Sep 2010 10:07am
darrenmax
nice to see its fixed Thumbs Up 2002 td6 vogue, 06 supercharged facelift
Post #27832 11th Sep 2010 11:29am
